Is there any reasonable way to repaint the vinyl "leather" part of the steering wheel. Of course, the wooden part is fine; the rest looks worn.
DIY Steering Wheel Vinyl Repaint (Vinyl/Leather Section Only)
What you’ll need:
  • Vinyl/leather prep cleaner (like SEM Soap or isopropyl alcohol)
  • Fine-grit sandpaper (600–800 grit)
  • Adhesion promoter (SEM or Dupli-Color make good ones)
  • Vinyl/leather spray dye (SEM Color Coat is a favorite)
  • Matte or satin clear coat (optional, for OEM finish)
  • Painter’s tape and plastic wrap (to mask off the wood section)
Step-by-step:
  1. Clean Thoroughly: Degrease the vinyl with a proper cleaner. Any oils or grime will ruin adhesion.
  2. Light Sanding: Gently scuff the surface to help the dye bond. Be careful not to go too deep — just enough to dull the sheen.
  3. Mask the Wood: Use painter’s tape and plastic to protect the wood trim. Take your time here — overspray is the enemy.
  4. Apply Adhesion Promoter: A light mist coat helps the dye stick and prevents peeling.
  5. Spray the Dye: Use light, even coats. Let each coat flash off before applying the next. Usually 2–3 coats does the trick.
  6. Optional Clear Coat: For durability and a factory-like finish, a matte or satin clear coat helps seal it in.
🛠️ Pro Option: Steering Wheel Restoration Services
If you want a factory-perfect result without the DIY hassle, Craft Customs specializes in restoring Lexus steering wheels — including re-dyeing, rewrapping, and even adding custom finishes. You send them your wheel, and they send it back looking brand new.
Here’s a solid video that walks through the process of restoring a worn vinyl steering wheel — perfect for your RX 300:
🎥 How to Repair Steering Wheel Vinyl by Craft and Restoration
This 6-minute video covers:
  • Removing the steering wheel (optional but helpful)
  • Sanding and prepping the surface
  • Using vinyl filler for deeper cracks
  • Applying dye or paint for a refreshed finish
It’s not Lexus-specific, but the techniques apply well to your RX’s vinyl/leather blend. If you’d prefer a Lexus-focused example, this Lexus Owners Club thread has some great community tips from RX 300 owners doing the same job. Conduct a search for links.
