jmh2025 Posted June 14 Posted June 14 so, followed the procedure to the T right, on my car 2011 lexus es350 I had a exactly 51oz or about 1.5qt come out, I put 2qt in the transmission 640z, once I did the procedure and waited for the correct temp and all, what came out before it started trickling was about 8-9oz so about 1/4qt which means that there is about 1/4 or 8-9oz more in the transmission then what came out originally, should I be worried? or is it fine?
dcfish Posted June 15 Posted June 15 2 quarts is normal, Did you ever think the fluid was low before you drained ? 2 quarts in is perfect.
jmh2025 Posted June 15 Author Posted June 15 Hi thanx for the response, well I had o reason to believe it was low since it shifted fine and quite frankly dont think it was ever touched. so in your opinion my roughly 1.75qt is fine right?
Hadyourphil Posted June 15 Posted June 15 I just picked up a beautiful '01 RX-300. Would its transmission also need 2 quarts for drain and fill? Any brand in particular for the refill? 1
dcfish Posted June 15 Posted June 15 1 hour ago, Hadyourphil said: I just picked up a beautiful '01 RX-300. Would its transmission also need 2 quarts for drain and fill? Any brand in particular for the refill? Hey Phil, Where in Sconi are you ? I am pretty sure the 2 quart drop and fill is pretty standard.
dcfish Posted June 15 Posted June 15 1 hour ago, Hadyourphil said: Manitowoc. Didn't want to buy too much tf! Ha, I'm just up the shore in Sturgeon Bay 🙂
