RiveraR Posted March 16 Posted March 16 Hello. I recently purchased a stock wing for my 96 SC300. Looking to find a mounting template to cut holes in the right spot. Any ideas? Thanks
McBrian Posted March 20 Posted March 20 Sit it on the car and arrange it in the right spot. Use a dry-erase marker to outline the shape where it sits on the deck. Make a template from the feet of the wing cutting out the shape and holes. Tape that to the deck. Drill (SLOWLY with a metal bit and plenty of lubricant!!!) Paint and treat both sides to avoid rusting (will still happen...) and you should be good. If you want to be really obsessive get some 1-2mm rubber and make gaskets.
