controlledchaos Posted March 14 Posted March 14 I changed my struts with spring, cv joints, control arms, balljoints, and linkages with a mevotech kit 10756. Since then on take off and stopping I can hear popping on both sides which sounds like struts. I can not recreate the sound by several of us pushing up and down on either side. What could this be?
Matt_ATX Posted March 20 Posted March 20 Did you replace the joints or the entire axle? and what brand did you use? I recently replaced both front strut assemblies with FCS. Drove for a couple of days and then realized the driver side cv boot had split during the strut install, so I replaced the axle with a cardone. I then started getting the same popping you describe when the weight transfers on start/stop, but only on the driver's side. I also replaced ball joint, sway bar link, outside tie rod, etc just because they needed it, but the pop is still present.
