Castro81 Posted February 14 Posted February 14 So I did my timing belt and water pump 2 weeks ago and now my trac off light is flashing scanned check engine and codes came back for tps and apps changed both and still nothing wondering if anyone else has had this issue and what they did to fix it. My next options were to replace the connectors and check the harness for anything that might be messed up.
Castro81 Posted February 14 Author Posted February 14 Replaced connectors on tps found some wires messed up and fixed them still running the same
Castro81 Posted February 18 Author Posted February 18 Replaced throttle body and accelerator pedal position sensor now runs maybe worse
