My 2016 RX350 will leave a small transmission fluid puddle after sitting for 2/3 weeks. It does not leak overnight or any other times. I cannot find were the fluid is coming from. the transmission housing is dry. Any thoughts ?
Thank you,
Stella RX
These types of leaks can be tricky to detect. Are you certain that it is transmission fluid? Having the vehicle put on a lift can make discovering the source of the leak a bit easier.
Hi,
The fluid on the floor is bright red, not a big puddle. This has happened before after the vehicle sat for a couple of weeks. I have crawled all over the under carriage and found no wet spots on the transmission case. There is no fluid on the floor overnight.
Thank you
