passado Posted November 30, 2024 Posted November 30, 2024 2000 RX 300 Center display out, accessories do not work? Is there a central fuse or breaker or relay?
RX400h Posted December 1, 2024 Posted December 1, 2024 13 hours ago, passado said: 2000 RX 300 Center display out, accessories do not work? Is there a central fuse or breaker or relay? CoPilot response: Quote Here are a few steps you can take to troubleshoot the problem: Check the Fuse: The fuse for the center display and accessories is likely located in the fuse box in the engine compartment or the passenger compartment. Refer to your owner's manual for the exact location and fuse number. If the fuse is blown, replace it with a fuse of the same amperage rating. Check the Relay: If the fuse is not the issue, the problem might be with the relay. Relays are switches that control the power to the accessories. You can find the relay in the fuse box as well. Swap the relay with another one of the same type to see if that resolves the issue. Inspect Wiring: If neither the fuse nor the relay is the problem, there might be an issue with the wiring. Inspect the wiring for any signs of damage or disconnection.
