Aftermarket Amp---need Help
The stock sub amp is busted but the sub is still good and I needed some help to put in an aftermarket amp.
-How should I run the power cable?
-The stock deck does not have RCA's but my amp has speaker level imputs?
-Do I need a high low converter?
-How should I tap into the speakers--I have the Nak sys
-Where is a good place to mount the amp?
-How many watts does the stock sub handle?
Confused :wacko:
Confused <!--emo&:wacko:-->wacko.gif<!--endemo-->
first i don't know where the stock amp is located
AWJ should have an answer for that
you don't need a high low as it is already in the amp
once the stock ampp is located then running wires from there to the trunk is one option
or runnig new wires to eac speaker is another
also changing the speakers might be a good idea as well as the system is tuned for the amp speaker and deck
take any part out and it will not sound as good
tapping into the speakers will not help as it wont have any output or signal as the amp is dead
you woul need to take the wires from the back of the deck to the amp
are you planning on chainging
just getting a small amp and a new sub might be easiest
and runnig the power iwre through the fire wall to the trunk
