taadow77 Posted November 3, 2004 Share Posted November 3, 2004 Hey guys - I was driving down the road with my rear and front fog on when all of a sudden my whole climate control panel turned off. Nothing now works let alone lights up. Does anyone know anything about this? Thank you in advance for any insight!! Quote Link to comment Share on other sites More sharing options...
jbarhorst2 Posted November 3, 2004 Share Posted November 3, 2004 Does your cigarette lighter still work? If not, it sounds like you blew that fuse, but that doesn't control the lighting - only the operation of the climate control. Tom Quote Link to comment Share on other sites More sharing options...
taadow77 Posted November 3, 2004 Author Share Posted November 3, 2004 Thanks Tom! I'll check it out just as soon as I find my lighter. God I hope that's the problem. Everything just went out all of a sudden. Thanks again! Quote Link to comment Share on other sites More sharing options...
xl8rguy Posted November 3, 2004 Share Posted November 3, 2004 See if you have a coin in your cigarette lighter. That happened to me once and shut down my HVAC display. I felt pretty stupid when the dealership found it. Quote Link to comment Share on other sites More sharing options...
DLaxMan3 Posted November 3, 2004 Share Posted November 3, 2004 Is your audio screen messed up as well if it is you might wan to reset it, to do this remove number 15 and 20 fuses for 30 seconds. Chech your SC manual to make shure those are the right fuses controling your head unit it has been a while since i did it. Quote Link to comment Share on other sites More sharing options...
DLaxMan3 Posted November 3, 2004 Share Posted November 3, 2004 you can also check to see if any are blown, the fuse bax is the small box on the left side if you are sitting in the car. Quote Link to comment Share on other sites More sharing options...
taadow77 Posted November 3, 2004 Author Share Posted November 3, 2004 Thanks Dlax! I'll check it out! Quote Link to comment Share on other sites More sharing options...
taadow77 Posted November 3, 2004 Author Share Posted November 3, 2004 Alright, Jbar - the cigarette lighter doesn't work. It's probably just a fuse. Thanks again for the tip. Quote Link to comment Share on other sites More sharing options...
jbarhorst2 Posted November 4, 2004 Share Posted November 4, 2004 Let me know if you need help finding the right one. But, there should be a little map on the inside of your fuse box cover. Tom Quote Link to comment Share on other sites More sharing options...
