I've recently replaced the rear left brake light bulb on my wife's RX300, and the rear light indicator on the dash board is still on most of the time. It is off when the car is first started, but remains on once the brake pedal is depressed.
Any suggestion ?
where did you get the bulb?
some are not the right resistance and cause the dash light to go off
I purchased 2 bulbs from Lexus dealer. Installed one a few months ago with no problem. However, the second one that I installed (on the opposite side) is the problem one.
Could be a bad bulb ?
