ok im re-wireing my 1995 ES300's audio system. anyone have a diagram or photo of the amp that shows what wires go to what speakers?
when you say you are rewiring the amp what are you exactly trying to do
replace the head unit, speakers, or wiring?
it shows a pink and a violet wire for it
but it also shows that for the front left as in colour coding
have you used a volt meter
on the wires
no never, my friend has rigged so many stereos so ill ask him
that you have ever used a volt meter?
or that the wiring i gave you is incorrect
the best though it get another speaker and connect it to the leads for the stock one as i think they are acessable under the shelf in the trunk
if it works then you kow you have to change a speaker and all the wiringing is good
