sashabeau Posted October 15, 2004 Posted October 15, 2004 I have done some research on performance drilled and slotted rotors some rotor mfg like brakestop or irotors put either zinc or cadmium coatings on there rotors. I can see were it will help on the slots and hubs, but not on the surface of were the pad would ride, but I have seen a lot of cars were the rotors are so shiney the look like silver. Can anybody give me some input on this. Also which is better cadmium or zinc Thanks, my lexus is a 04 gs300
GuyTelefunken Posted October 15, 2004 Posted October 15, 2004 All rotors rust. Period. The swept area under the pads will stay clean from regular use. Coatings may help on the "hat" as some call it, but not on the swept surface.
TurboGS300 Posted October 16, 2004 Posted October 16, 2004 All rotors rust. Period. The swept area under the pads will stay clean from regular use. Coatings may help on the "hat" as some call it, but not on the swept surface. ← Yeah, What guy said!!! :D
BA_GS400 Posted October 16, 2004 Posted October 16, 2004 those coatings you're referring to are only put onto the "non-pad" area. you can certainly delay the rusting of the had and finned area by these coatings, or, try to G2 brake paint. It is good stuff. Perhaps those other rotors are still shiney because the owner drives like an old lady. Perhaps the car lives in a garage most of it's life. I doubt that they are doing anything 'special' to achieve that look personally. ps. zinc is a good rust preventative. look at some of the good stuff at www.eastwoodcompany.com
dcfish Posted October 17, 2004 Posted October 17, 2004 those coatings you're referring to are only put onto the "non-pad" area.you can certainly delay the rusting of the had and finned area by these coatings, or, try to G2 brake paint. It is good stuff. Perhaps those other rotors are still shiney because the owner drives like an old lady. Perhaps the car lives in a garage most of it's life. I doubt that they are doing anything 'special' to achieve that look personally. ps. zinc is a good rust preventative. look at some of the good stuff at www.eastwoodcompany.com ← Guy, You are the best !!! there is zinc coating which is the most economical, It protects the rotor except the surface where the pads are received , Cad - waste of $ Try lexuspros.com they have decent specials on rotors and plating right now !!
SKperformance Posted October 17, 2004 Posted October 17, 2004 My rotors are plated and i don;t drive like a granny. But my rotors are reflective enough to see my reflection from my driving style of just enough pressure when needed, so i almost never get warped rotors from overheating/cooling. G2 is a great caliper paint. I would NOT use it on the hub surface as it will not let the wheel seat properly, i did it so i know. A thin layer of black spray thermal paint works great on a nwe rotor
