Bill560 Posted May 28, 2003 Share Posted May 28, 2003 The transmission in my 1993 ES300 has gone bad. When it gets warmed up it stops moving! I tried looking around for one and they seem to be big bucks. Even from a junk yard. Is there an option here or am I stuck looking for a 1992 -1993 trans from the ES300 and Camry? Any help or suggestions would be great! Thanks Bill Quote Link to comment Share on other sites More sharing options...
SKperformance Posted May 29, 2003 Share Posted May 29, 2003 have you dropped the tranny pan taken out eh mesh filter and cleaned it it may help alot did with miine also may be a clogged return line when is the last tiem you did a fluid change but yes you are stuck with a 92-93 modle camry or es 300 tranny not sure if earlier models shared and will work as they where 2.5 L Quote Link to comment Share on other sites More sharing options...
Bill560 Posted May 29, 2003 Author Share Posted May 29, 2003 Yes the fluid was changed and when the pan was down it was checked. No luck. I can still drive the car untill it gets real heated but hen thats it. Thats why I thought a fluid change and cleaning would have done it, like you said. Thanks Quote Link to comment Share on other sites More sharing options...
SKperformance Posted May 29, 2003 Share Posted May 29, 2003 when you say checked what do you mean? did they ermove it as the mesh can only be seen through a little hole in the metal cover from the top and a solvent need to be swished around in there for a while to loosen it there is a vavle in the tranny that opens up when the tranny warms as to warm the fluid to operting temp maybe that is giving a problem also what tranny fluid are you useing synthetic or regular when the do a flush do the just loosen the bolt and drain the fluid or fun the engine to hot then remove the cooler lines to feed and drain the old and new fluid since to get at most the fluid the tranny has to be hot as that valve will not circulate the fluid through the whole system Quote Link to comment Share on other sites More sharing options...
Bill560 Posted May 30, 2003 Author Share Posted May 30, 2003 I guess thats what happens when you assume "THEY" checked it and did it right. I will take the time and do it myself this time. Is there write up somewhere on this or can I find the instructions in a repair book or the Aldata Repair dvd system? I have to plead ignorance because I dont know what was checked and what they used for fluid. What should I use and any help on the procedure would be great! Thanks Bill Quote Link to comment Share on other sites More sharing options...
