Wheels And Tire Size Help.
On my 2004 gs300, I am putting on new wheels 18x8 18x9. I might want to go to 18x10.
on the 18x9 I would use 265-35-18 can I use the same for 18x10? Also can anybody tell me, is the look noticeable between the 9s and 10s
The 265/35s will fit on the 18x10. It just may look a little more stretched and the sidewall will be a little shorter. It is better to use 275/35s on the x10 wheel.
As for can you tell? Yes, especially if you use the 275s. I went from 265/35s on 18x9.5 to 275/30s on 20x10. I know the specs are different but from behind, I gained .5" with the rims while gaining 10mm with the tires. Obviously, the two gains are not independent but the .5" gain allows the 275s to mount a certain way. Looking from behind, I an totally tell how much meatier the tires are.
I had 430 wheels on my 04 gs300 245x45 looks weird, but they barley fit
225x45 or 245x40x18 I have trd sc430 chrome trd wheels 18 which I will be selling when my new wheels arrive I went to a staggered setup 18x8 18x10 I have a set of fuzion z1 with less than 700 miles 245x40 x18 all around email me if your interested leonescu@aol.com
