skippy911 Posted September 10, 2004 Share Posted September 10, 2004 Just wondering if someone could point me in the correct Re & Re of the fog lights. Do I remove the inner fender well & go from there ? Or go in from the bottom ? Thanks in Advance MC Quote Link to comment Share on other sites More sharing options...
steviej Posted September 11, 2004 Share Posted September 11, 2004 I found on my ES it was easy to jack up and support the front end, remove the splash guard and go up from the bottom. When I changed out the bulbs for my ES fogs, the mounting hardware for the fog light itself was right there. The IS may be similar. steviej Quote Link to comment Share on other sites More sharing options...
JCE102JZGE Posted January 16, 2006 Share Posted January 16, 2006 if u stick your hand in the scoop right next to the fog light on the outer side u will feel two screws. or u can also look and see. all u need is a ratchet wrench, 10mm that short enough to fit in there. and you can losen those two screws and pull it out. but be carefull when using the ratchet make sure u dont hit the paint. to me thats the easiest way because of the fact u dont gotta remove anything else. Quote Link to comment Share on other sites More sharing options...
steviej Posted January 16, 2006 Share Posted January 16, 2006 if u stick your hand in the scoop right next to the fog light on the outer side u will feel two screws. or u can also look and see. all u need is a ratchet wrench, 10mm that short enough to fit in there. and you can losen those two screws and pull it out. but be carefull when using the ratchet make sure u dont hit the paint. to me thats the easiest way because of the fact u dont gotta remove anything else. dude, you are responding to a thread that hasn't been active for over 16 months. your have done this in many threads all in one morning. chill out a little, I know you just got a new car and your excited, but enough is enough. You are waking up dead threads. On the other hand, Welcome to the club, steviej ES/IS Forum Moderator. Quote Link to comment Share on other sites More sharing options...
JCE102JZGE Posted January 17, 2006 Share Posted January 17, 2006 haha really? damn i havent even paid attention to the dates. i gues si posted alot of replies cuz im looking for alot of information. my bads man. Quote Link to comment Share on other sites More sharing options...
