I searched the forums and found nothing to help me out. It's not the ashtray.
any help out there???
Sorry for the brief details. I was hoping that someone had the silver bullet for this.
Sounds come from the right side dash. I rode as passenger and attempted to isolate the ususal suspects: glove compartment door, contact points between dashboard interfaces, contact points between vinyl and plastic, radio support point. I used paper to minimize the friction between the above areas. All to no avail.
I'm afraid the problem might lie in a loose wiring harness inside the dash. In that case, the cure is worse than the disease.
Thanks for any help!
It might be your upper strut mount making the noise.
I also have a rattle in the dash on the left side. Each time I ask my mechanic to check it out, there's no noise. I may have to take it to the dealer, and they will replace the hold dash. I thought it might be from my cyrstals going out in the dash, even for that the hold dash has to be replaced ($600). :cries:
