Brake Failure
harippa
never heard of a brake pedal being too stiff. but it could be clogged lines or if there is enough moisture in the system that could lead to the master cylinder getitng corroded and it could fuse the bore and piston together but i have never heard of that happening or maybe the peddal mechanism froze? or maybe the abs is !Removed! up? either way you should get it checked out.
