Pipe At Back Of Engine Loose
BruMax
My 94 LS 400 has a pipe at the back of the engine near the top it’s about ½ to ¾ in diameter and appears to be bolted to the engine with a flange. It also appears to have some sort of seal or gasket in it because you can pull on the pipe and it almost seals up the leak. Engine runs fine, with no problem. But you can hear this noise some times. Any one have any ideas. :wacko:
