I have a 1993 LS400 which has a sunroof that leaks on the front corners whenever it rains really hard. Normal car washing does not effect it, but on a hard rain it visibly leaks in the corners. Any suggestions?? Thanks!!
you have drain hoses in each corner. check the front ones to see if they might be obstructed either at top or bottom. open roof and you should see them at the corners of front track,etc.
Right on the money!! Follow Richards advice!!!
Take a wire to "fish" down the drain holes - about 5-7 feet; so you can see it from underneath the car - then you'll know it's through.
