Airbag Light
willfitz69
:blushing: I just replaced a repaired instrument cluster and the airbag light in the instrument panel stays on. I also replaced the cluster with the battery connected. Does anyone know how to reset the sensor, or must I take it to a Lexus dealer. It's a 1993 LS 400 with 77,000 miles. I already disconnected the battery hoping to reset the computer.
you may have bought the car with the light always on
but burned out so the new cluster is showing it to you know
there is a fuse for the computer to rest but
you really shouldn't have changed it with the battery connected
I too had a guage repair, (twice actually) and found that each time you disconnect the gauges, and then re-connect, it lights the air bag light. My lexus dealer re-set it for free...If you can believe it!. If you bring the car into a dealer, make sure you tell them to just RE-SET the air bag light, not diagnose the "problem" ( you know what caused it). This should keep the cost to a minimum. Good luck!
