twilhoit Posted May 11, 2003 Share Posted May 11, 2003 anyone replace their IS 300 passenger air filter and can pass on some instruction? Quote Link to comment Share on other sites More sharing options...
bartkat Posted May 20, 2003 Share Posted May 20, 2003 This is covered in the owners manual under "cabin air filter". Look at the hinge on the glove compartment door, underneath. The hinge pins are made to be pulled out. The heads of the pins are to the inside. Use a fingernail or plastic tool to pull the pins so you can pull them completely out. Then you can completely remove the glove compartment, door and all, in one piece. Behind there is a rectangular plastic panel. Just pull that panel out and you can see the filter. It's very similar to the engine air filter in appearance. Just slide out the filter and put in the new one. Then replace the plastic filter cover and then replace the golve compartment into the dash. I ordered a cabin air filter plus some Lexus oil filters from this site. http://www.irontoad.com/Merchant2/merchant...=2002is300sedan Quote Link to comment Share on other sites More sharing options...
bartkat Posted May 22, 2003 Share Posted May 22, 2003 The oil and air filters I ordered just came in. I changed the cabin air filter. I'm just so proud I did some maintenace on a LEXUS. c (ex Honda Civic driver) ;) Quote Link to comment Share on other sites More sharing options...
hvrod Posted July 2, 2004 Share Posted July 2, 2004 Go thru the glove box.. Quote Link to comment Share on other sites More sharing options...
hvrod Posted July 2, 2004 Share Posted July 2, 2004 check the internet for a replacement.. vs dealer.. can save you some $$$$ Quote Link to comment Share on other sites More sharing options...
ssdisciple Posted July 21, 2004 Share Posted July 21, 2004 :D Actually, you don't even have to take the glove box door off....just carefully release the door forward and the filter cover will be exposed....in upper area of compartment. The plastic filter cover is right there....it pops off and the filter slips out for easy replacing. Place cover back and put glovebox back into dash carefully....NO TOOLS NECESSARY!!! I've done it several times!!! Scott 2002 IS 300 Quote Link to comment Share on other sites More sharing options...
pcoyle Posted July 21, 2004 Share Posted July 21, 2004 I just changed mine yesterday, with a $15 Purolator filter from the local major auto parts store. I didn't try it with the door on, but taking to door off / putting it back was simple. The OM's directions were perfect. Quote Link to comment Share on other sites More sharing options...
