bezee Posted July 6, 2004 Share Posted July 6, 2004 I took my car to the dealer for a diagnostic test and i was told my rear differential was leaking and they want $432 to fix it. I looked under to see if i could see the leak and i can see that the case is wet. Is there a way to fix the seals ?Because i really dont have the $432 the dealer wants so im lookin for an alternative fix that i could have my mechanic do. Any suggestions??? Quote Link to comment Share on other sites More sharing options...
johnny3 Posted July 6, 2004 Share Posted July 6, 2004 Any auto-mechanic can replace the differential seal, very straight-forward simple job. Quote Link to comment Share on other sites More sharing options...
bezee Posted July 6, 2004 Author Share Posted July 6, 2004 So most likely its the differential seal that's causing the leak? Quote Link to comment Share on other sites More sharing options...
bean_8044 Posted July 6, 2004 Share Posted July 6, 2004 The only other likely thing is if the gas tank is leaking onto the diff or the diff has a hole in it. Otherwise, you could replace the gasket. Just take off the cover, scrape the gasket off the diff, put a new gasket on the cover, tighten down the cover. Done Quote Link to comment Share on other sites More sharing options...
