92ES300 Posted May 8, 2003 Share Posted May 8, 2003 I am trying to take out my HU from my 92 es. I took off the trim under the HU, then removed those screws. I tried to take out the two screws inside the ac vents above the HU, but I cannot get the screwdriver lined up right, because the screw is pointed up, not straight out. So, I need to remove the vents, but how?? I was told to pry out the vents, but I am not sure how they will get back into place if I do that? I really need help because the knob is getting loose, and I am afraid it will stop working all together soon. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted May 8, 2003 Share Posted May 8, 2003 there are no screws on the vent it is just held in place by clips it takes time alot of it infact to remove the vents it must be done slowly to make sure you don't break it i think there are 2 above and below the vent holding it in place then you can acess the bolts holding the ac / radio braket in place Quote Link to comment Share on other sites More sharing options...
92ES300 Posted May 8, 2003 Author Share Posted May 8, 2003 so I should just use plyers on both sides, and pull little by little one side at a time? Or, should I pull the tops, then bottoms? I just want to be sure, so I don't mess anything up. Quote Link to comment Share on other sites More sharing options...
