Hi,
I have been getting this check enging light for over a year along with the TRAC light. The TRAC does not turn off. The TRAC button does not work either.
However, a couple of months ago, TRAC came back to life briefly for one day :P , with the TRAC light turned off and the button working, and then it went bad again :angry: .
At what occasions do I get the CHECK ENGING light? Could the TRAC problem cause the CHECK ENGING light on?
Could this be oxigen sensor problem?
Other than the lights on the console, I do not notice much abnormal behavior or performance downgrade of my car.
Please advise.
Thanks,
It's simple. PM me your e-mail and I'll send you the simplified procedure. You should always at least check the code to find out what it is. Others have the same issues but I forget what the cause and cure is.
find some one with an obd1 scanner this will solve your problems
You need a OBDII (that's Onboard diagnostic version 2) scanner to get the code.
Hey AWJ is there another way to get the code ??? :blink:
  • 3 weeks later...
Do the mechanic shops usually have the code reader?
The place I visited last time didn't have it for model year 95.
Would Firestone have the scanner?
Thanks,
