BARNEYHYPHEN Posted June 28, 2004 Share Posted June 28, 2004 2000 LX470 76,000 MILES. WILL NOT START. TURN THE KEY AND GET ONE "CLICK". MAYBE 1 IN 20 ATTEMPTS THE ENGINE ACTUALLY CRANKS AND THE CAR STARTS. BATTERY TESTED YESTERDAY AT AUTOZONE AND CONFIRMED GOOD. SOUNDS LIKE A SOLENOID PROBLEM? DO I REPLACE JUST THE SOLENOID ($90+) OR THE WHOLE STARTER ($200+)? IS THE STARTER ACCESSABLE? HOW LONG SHOULD THE JOB TAKE ME? VERY MECHANICALLY CAPABLE BUT ANY AND ALL ADVICE WOULD CERTAINLY BE VERY MUCH APPRECIATED. THANKS. 1 Quote Link to comment Share on other sites More sharing options...
itmdtr Posted June 29, 2004 Share Posted June 29, 2004 The starter is located underneath the intake plenum/manifold. For the work it takes it might be wise to replace the entire starter. Quote Link to comment Share on other sites More sharing options...
a_lu_co Posted September 15, 2005 Share Posted September 15, 2005 Hi there, how did you end up with the starter? My LX 99 has the same problem, and was wondering if I could just change the solenoid, or the entire starter. Thanks Quote Link to comment Share on other sites More sharing options...
hoser Posted September 16, 2005 Share Posted September 16, 2005 Step by step, how to change your starter contacts. http://forum.ih8mud.com/showthread.php?t=9117 Quote Link to comment Share on other sites More sharing options...
Jim_Chow Posted September 17, 2005 Share Posted September 17, 2005 I also vote for starter contacts. Sounds like you have the classic symptoms. Make sure you change the plunger rather than the contacts only, just to be sure. Quote Link to comment Share on other sites More sharing options...
