Advice On Rotor And Pad?
I am trying to replace the stock rotor with aftermarket better performing rotors with appropriate pads at the same time.
I hear about Brembo slotted rotors. Is it true that the slotted performs better than drilled? Also the slotted requires special type of pad, or does it eat the pad?
Let me know if you have any recommendation.
Thanks,
