20 Inc Tires Helllllllllllppppppppppp
hey I just purchase some new tires for my car, they are 255/35/20 and they are rubbing, I only put them on the front. since I drove the car I am stuck with them any idea's on how I can get them to stop rubbing.....also do you think they will rub in the back too?
The rear you should be fine.. If you would have asked me first before you went ahead and got your tires I would have told you to get 245/35 instead of 255's.. I used to have 255's and the rubbed when I would turn hard.
check it, I just remembered that you said that you only put the front tires on.. Bring back the 2 tires that aren't mounted and get 245/35's.. The put those on the front and switch the other ones to the rear..
thanks I just had the tires put on the back and well they sound better than the front, I am exchanging my other 2 for 245/35/20
Good.. And now with the 255's in the rear it'll be wider and semi staggered..
