GRD Posted June 8, 2004 Share Posted June 8, 2004 My LX470 side mirrors are not working from the switch or lowering when you put the vehicle in reverse. The dealer checked it out and said that they need to be replaced at $1700!!!! Yikes Any ideas? Thanks, George Quote Link to comment Share on other sites More sharing options...
jrwright Posted June 9, 2004 Share Posted June 9, 2004 They both went bad at exactly the same time??? That sounds fishy. Backtrack the wiring, could be a simple fuse (which the dealer should have caught). If not, maybe a bad switch?? I would guess that both mirrors wouldn't go bad like that, maybe one, but not both. Quote Link to comment Share on other sites More sharing options...
davetruong Posted June 9, 2004 Share Posted June 9, 2004 GRD, I took mine in, and the dealer replaced it under warranty. Apparently, this happens quite a bit. Contact Lexus USA directly to see what they could do. If that doesn't help, there are some mirrors on Ebay right now. Search under "LX470" Good luck Quote Link to comment Share on other sites More sharing options...
GRD Posted June 9, 2004 Author Share Posted June 9, 2004 GRD,I took mine in, and the dealer replaced it under warranty. Apparently, this happens quite a bit. Contact Lexus USA directly to see what they could do. If that doesn't help, there are some mirrors on Ebay right now. Search under "LX470" Good luck Thanks, I send an e-mail to Lexus USA. The car has only 40K. The mirrors shouldn't just stop working at the same time, but the dealer couldn't fix them. Hopefully Lexus will help out. Thanks again, George Quote Link to comment Share on other sites More sharing options...
jrwright Posted June 10, 2004 Share Posted June 10, 2004 40K miles? Why did the dealer tell you that you had to pay for it? 50K mile bumper to bumper warranty! Quote Link to comment Share on other sites More sharing options...
kcmj1234 Posted June 17, 2004 Share Posted June 17, 2004 My LX470 side mirrors are not working from the switch or lowering when you put the vehicle in reverse. The dealer checked it out and said that they need to be replaced at $1700!!!! YikesAny ideas? Thanks, George Did you check if the switch was set to L or R? If the switch is set center, it is not working. Quote Link to comment Share on other sites More sharing options...
jarcara Posted June 23, 2004 Share Posted June 23, 2004 I had a similar issue where my mirrors would not return to the proper setting when put in reverse. I have a 2000 LX470 w/62K miles. The dealer called Lexus and they covered it under warranty (which this is out of). I just paid $90 labor. I called every manager at the dealership including the owner to tell them how above-and-beyond my service tech went for me. Otherwise it was $1,300 to replace them. Quote Link to comment Share on other sites More sharing options...
