Sweet-Tee Posted June 2, 2004 Share Posted June 2, 2004 The dealership stuck their advertising decal on my car(above the Lexus sign) :chairshot: I want to remove it without damaging the paint. This is not the type of sticker you can peel off or atleast I can't see the corners to lift and peel. Any idea if that spot will be a different color than the car? and how can I remove decal? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
lexo Posted June 15, 2004 Share Posted June 15, 2004 :o I hate when they have to put their name on our car.... It is not painted on right? most dealers will not go to that extent..... So try to find an edge. Get out the hair dryer on low, touch over until it is warm not hot! and see if you can get a corner started with your finger nail.... it will have to be a thin vynal decal.... afterwards use some fine polish to finish the job off and remove any sticky stuff with goo gone...Hey the best way just for *BLEEP*s and giggles to get off emblems is soapy water and dental floss..... LEXO ;) If the sticker has been on a while the spot may be off colored.... :( Quote Link to comment Share on other sites More sharing options...
BRAKATK Posted June 16, 2004 Share Posted June 16, 2004 I have removed stickers and emblems with alcohol (like rubbing alcohol) to dissolve the adhesive and not harm the paint. That's my experience-good luck! Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 17, 2004 Share Posted June 17, 2004 Can you post a picture of it? Quote Link to comment Share on other sites More sharing options...
tomanji Posted June 20, 2004 Share Posted June 20, 2004 yeah the blowdryer is good, you will be left with residue..if you dont have any goo gone around you can also use wd-40 it works very well.. spray it on.. let it sit for a sec and then just wipe it off. then polish away.. Goodluck Quote Link to comment Share on other sites More sharing options...
