All Activity
- Today
MotorCity joined the community
95elijah95 started following Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
95elijah95 joined the community
Terry Mace joined the community
Snap on part on left rear side of luggage rack flew off. Anyone know where can obtain one. Searches did not reveal a silver one available.
- Yesterday
front cam end cap can anyone tell me how to get it off.
paulo57509 replied to Abe Scott's topic in 90 - 00 Lexus LS400
Did you get the cap off? -
Hello, Mike. You may want to check with a Lexus dealership parts department person.
2004 RX330 2 issues- D light and cruise
RX400h replied to HD75's topic in 04 - 09 Lexus RX330 / RX350 / RX400h
Rplyler joined the community
Don 139 changed their profile photo
- Last week
drdre816 joined the community
davidchil joined the community
Dean2 started following Timing belt.
They have been made by Aisin for decades and Japanese producers do not switch suppliers easily at all. Long term relationships are how they run their businesses. I would assume they made them for those too.
- 1 reply
- 1
Vince Ellero joined the community
Jefft112 joined the community
Jefft135 joined the community
sca1313 joined the community
Celsior-Horn,dome light,door switch,power mirrors,and more
Fi7e replied to Fi7e's topic in 90 - 00 Lexus LS400
Let me refine and simplify my issue. Anything not listed below works fine. -Key remote will pop trunk. It only beeps if I push the Lock button but not Unlock. Won’t unlock/lock doors. -Power locks don’t work with or without key remote. Locks only work manually. -Window switch only works after I lock/unlock the door, then works fine. Master switch only controls drivers window -Horn doesn’t work - fuse is good and I can hear the horn relay clicking when horn is pressed, so that rules out bad switch or clockspring. -Dome light doesn’t work on “door” setting, but works when switched to “on” position. -Drivers side seatbelt height adjuster doesn’t work, passenger side does -Side mirror adjuster doesn’t adjust either mirror -Power folding mirrors don’t work, mirror vibrator works -Seat/steering wheel memories won’t program or work - all seat and steering wheel adjusters do work. All fuses are good. Haven’t checked every relay though. No CEL or Airbag lights. -
myates88 started following Timing belt.
I’m trying to find out who the original manufacturer was for the timing belt in a 1992 sc400. Does anyone know by chance
Lexus RX350Guy08 started following Mid West
Oh, details.. ’06 GX470
TwoShedsRX started following OK to drive GX470 2005 in 4 wheel drive High all the time??
Now wait a minute. I have owned an FJ80, an LX450 both were FULL TIME 4WD which means unless you Stop/neutral , shift your transfer case into “4lo” you , by default in 4hi the rest of the time, NO? What you DO NOT want to do is drive on pavement with the Center Diff. locked- very bad. If we all take a look at our GX470’s transfer case shift lever you will see it says “H/N/L therefore if you’re not crawling as long in 4low your only choice is 4hi. Not trying to be a Weisehiemer. I just assumed we all knew what we are driving.
My Burgundy Pearl on burgundy LS400
Images added to a gallery album owned by FurryLexus in Lexus LS 400 and LS 430 Models
Which of your vehicles?
My dash indicates on my rear door is open on my Lexis GX470
RX400h replied to Wellman's topic in 03 - 09 Lexus GX470
Aftermarket is at fault.
200 LX470 OEM remote finally died. Purchased aftermarket and had it programmed by a local locksmith. My issue is distance for the remote to operate…it will only function within 10” of the front windshield. I have tested and replaced the remote battery three times. Could this be the range of the aftermarket remote or something within the vehicle (receiver)?
2014 Lexus ls 460 AWD Trans Fluid Change
srgilbert replied to srgilbert's topic in 07 - 16 Lexus LS460 / LS460L / LS600h
Well I have the supplies but have not performed the change yet. I have had the battery disconnected a couple times and that seemed to help for a while - no idea why. Checking with Lexus the transmission has the latest software. -
I own a 2000 RX 300 first my parking brake light remains on even though the parking brake is not on, next the windows including the sun roof would roll down when I touched the driver's window button or when I turned the ignition key to off position. Now the engine light comes on and off and there is a different sound coming from the engine. Overwhelmed with all I took the vehicle to a Toyota dealership near me and was told that I have sludge and the engine needs to be replace. I not sure what to do. Please give some advise.
dstrz replied to srgilbert's topic in 07 - 16 Lexus LS460 / LS460L / LS600h
@srgilbert I too am experiencing some 3-2 and 2-1 downshift harshness on a 2014. I’m curious if you were able to get the fluid exchanged, what method you ended up using, and if it resolved your issue. -
What did you do? How'd you make out?
Looking for a transfer case for my 2004 GX470
Trust me, I’ve searched and watched almost every YouTube video I can find. my car is a imported 1997(1998) Celsior with only 42,000 miles and bone stock. Runs/drives great. here’s the full list of what’s not working horn, door dome light, power folding mirrors/mirror adjusters(mirror vibrator works), remote key, saved seat/steering wheel memories, master window switch/lock(drivers window works)[all window switches work at each door], don’t think my bumper cornering blinker lights turn on with blinkers(bulbs are good), drivers side seat belt height switch, and I think I found out today my cruise control doesn’t work. Checked EVERY fuse in engine bay and kick panel, all good and clean. Dome light turns on manually but won’t with doors. Every light works except possibly my cornering lights. All other systems work perfectly. Touch screen is fine, radio works, function buttons on steering wheel works, all electric seat buttons work, steering wheels telescope/height, etc. no dash codes or check lights on. many people have one or two of these issues independently but not all together, and their fixes are usually fuses or high mileage wear and tear. The key remote has newer batter and will beep but not unlock the doors. i have unplugged the battery a number of times but none of the typical system resets seem to work in my situation. I have a hard time believing all these systems are connected to one problem but my friend i got the car from drove it from the port in Cali all the way up the coast to WA and said EVERYTHING worked perfectly before it sat for a number of months.
Topics
