All Activity
- Today
djambo joined the community
Rotten Egg Smell In Ls-460 And Break Noise
djambo replied to Mercury Chariot's topic in 07 - 16 Lexus LS460 / LS460L / LS600h
Hello all, even though that is an old topic ( sulfur smell inside the vehicle), I would like to know whether a solution has been found by any of you. I found the leak on both sides of the center console ( between the front seats), and Im sure of it because there are white residue prints on both side of the plastic side cover and the carpet under it smell the same. In my case, I dont drive above 2000rpm, and mostly is noticeable when I park the vehicle for some time and close the windows. What is strange is that no smell is present when you stat next to the vehicle, but once you open the door, it is hitting you in the nose directly. Thanks in advance! -
Trpy changed their profile photo
Trpy joined the community
Thanks. I replaced the battery and the charge was covered by Lexus, although I have been unable to confirm if the battery was bad (long story). In the final analysis, either the battery was bad or the charging mechanism (alternator or otherwise) wasn't working. If the former is the case, then the problem has been solved (hopefully). If the latter, either that is a significant engineering defect or I need some direction on how to keep the 12 V charged. The question is whether the 12 v battery charges while the car is on EV mode. If the 12 V runs down after every few hundred miles, then that is not sustainable and if there is something in my driving habits (such as operating almost exclusively on EV mode) that needs to change, it would be useful to know. In the meantime, I am getting jumper cables. Until this happened, I had no idea that these were necessary for a PHEV.
Vincent Perez joined the community
dewana421 started following Wiring harness for 2008 ES 350 aftermarket stero
dewana421 replied to Hokiescottyp's topic in 07 - 12 Lexus ES350
Hi. I’m having the same issue. Did you ever figure out what harness is needed? -
Vincent Robertson joined the community
- Yesterday
Bobby Z. joined the community
Hi Dave, Thank you for your suggestions. It will be a few months before I need an oil change, but when I go to the Lexus dealer I will ask the service adviser about it. Incidentally, when Lexus corporate sent me a form letter welcoming me an as owner I did respond with my above concern. I received a reply the next day or two essentially saying that Consumer Reports is an independent testing agency and I should contact them about their report on major reliability problems with the aforementioned engine. I wrote back thanking them for their prompt reply, but I (politely) pointed out that the double down red arrows were not the result of testing but instead based upon a reader survey of owners of the 2021 NX300h. I didn't hear anything back and that was a few weeks ago so it's safe to say that Lexus corporate is disinterested and considers the matter closed.
Hello, Bill. Who tested the battery, and was it load-tested? Obviously, not starting after one week is not normal. Is your remote fob battery good? If that battery is week, you can sometimes verify by placing the fob against the vehicle's start button as you press that button. A weak fob button can often allow the vehicle to start if you do it this way.
Rocket Scientist joined the community
Something is draining the battery
Rocket Scientist replied to Haliuna's topic in 2013 - 2018 ES350 / ES350h
I have a 2013 ES 350. If I let the car sit for over a week the car won't start. Easy to start with a boost charger. Battery tests good. I read in the manual about turning off the receiver module by using the Park on/off button. This will turn off the draw of the receiver if you are not going to drive extended periods. Any comments from the group? Bill in Denver -
KChou joined the community
EL X570 joined the community
Fast Eddie G joined the community
RX400h started following Consumer Reports Warning on 2021 NX300h Major Engine Problem and Intermitent idle/vaccum issues
- Last week
Flash413 started following Consumer Reports Warning on 2021 NX300h Major Engine Problem
I am brand new to the forum so please bear with me . . . In Feb 2024 I purchased a low miileage 2021 NX300h. Shortly thereafter the April 2024 the annual auto guide issue of Consumer Reports magazine was published.On page 92 they give the 2021 NX300h double red down arrows for Major Engine problems which is disconcerting to say the least. Has anyone experienced major engine problems on this fairly new model? Thank you.
phazedphoton started following Intermitent idle/vaccum issues
Hello, I have a new to me 02 rx300 with 170k on the clock. Im trying to figure out some issues Ive discovered and haven't found anything conclusive enough to fix. Thus, Im reaching out for help, all input would be appreciated. The issue is partially intermittent. On idle when car is in gear and rpm is low ~600 there is a dead miss on 1-2 cylinders. It clears up as the rpm is increased. Additionally, the car suffers a low vacuum condition on occasion (largely after rough idling for awhile, or driving with the engine at low rpm). This loss of vacuum impacts the brake booster, which I find unacceptable and have been driving my other car (a 90' v12 jaguar xjs) instead. Not terribly practical. I have generally looked for vacuum leaks without success. Have tried using smoke and noticed a flow of smoke to the booster area but haven't seen anything conclusive. Im also not convinced its a vacuum leak. It seems to happen intermittently, and like a switch if its good the car operates properly and other times, its rough and I ended up easing the car home without sufficient boosted brakes. Additionally, just by feel sometimes it seems the valve timing is not quite where it should be. Which has me suspecting the vvt system, which could potentially impact intake vacuum. I dont have all the codes with me but they were just general misses not cylinder specific. I know almost nothing about the maintenance of the car, someones been here before. It has new plugs (didnt actually check back cylinders) and doesn't seem like an ignition issue. One of the screws on a vvt solenoid was replaced but the solenoid is original. I know bench testing solenoids isnt always an accurate way of determining if they are ok. Im tired of having this issue and im ready to dig in to fix it. Let me know what things I should look at or address, Id love to hear your input. Im leaning towards replacing vvt solenoids, filters, and cleaning the iac valve (should I consider replacing the actual actuator?) Best,
RX400h started following touch screen
2003 ls 430 135,000miles. The touch screen just started working sporadically
Have a 2004 ES 330 that is having, what sounds like, a similar problem. The battery and starter seem to work fine. It will start and work great, but every once-in-a-while, it doesn't start. All the dash lights come on but the starter won't kick in. This seems to happen most often just after filling the gas tank. Wondering if anyone else has experienced this. It has been to the mechanic three or four times for this, but it still happens. The first time, we just tightened the gas cap and that worked. I purchased a new Toyota gas cap about 18 months ago because of an evap system code, but we still continue to have this issue.
There is no alternator in a PHEV. It is a hybrid, where you can charge the extra large high voltage battery home via a plug-in. Hybrid cars have no alternator. Like I mentioned before - the 12V battery starts the computer that then power up the big battery. The car can run on the big battery till there is too little power left in that and then the vary ordinary engine running on gasoline starts to charge the battery and power the wheels. Call your Lexus where you bought the car and tell them to help. A new car should have some service free of charge.
Thanks. This a PHEV so the issues are different. The 12 V battery ran down and there can only be two causes: The alternator is not working The battery is bad. Since it has an electric engine and I rarely run it in HV mode I am interested in knowing if the alternator works with the EV engine. If not, it is obvious I will have to run the car regularly on HV mode in order to keep the battery charged. I drive the car regularly but rarely use the HV mode since my distances are short.
Lexus-CT started following 12 V battery
A 3 month old car is warranted. Suppose you mean NX and not Nh. 12V battery powers up the computer that power up the high voltage battery that start everything else. 12V battery is rather tiny and if car stand still a long time, the battery lose power. The little CT we have is a 2017 model and 12V battery is still just fine. Charge the 12V battery and it should start everything else again. But do mention it to the dealer as a brand new car should have a brand new battery that keeps charge well.
roberts261 started following 12 V battery
My 12 v battery on my NH450 plus died the other day. The car was three months old and had less than 1000 miles.I could not unlock or start the car. Until this happened, I was not even aware that there was a 12 V battery which apparently powers all the ancillary electronics. I simply assumed that the main battery powered everything. I don't drive far and rarely use HV mode but I do drive regularly (at least 2 times per week). I am wondering if this happened because the alternator only runs on HV mode. I suspect that the designers did this to increase the battery range and the car needs to be driven in HV mode at regular intervals in order to prevent this problem. Anyone have any information on this? Does anyone know if the driving in HV mode is necessary to run the alternator and thus keep the battery from running down? It seems that if operating on HV mode at regular intervals is necessary, owners of these vehicles should be warned and advised to drive on HV mode at regular intervals.
KZZ started following How about the all-new 2022 LX600?
mattwall started following Water Leak Into Passenger Side Floor
mattwall replied to zeppo's topic in 04 - 09 Lexus RX330 / RX350 / RX400h
I'm confused. Where did you end up routing the hose to? -
I had the same problem with AFS on my 2007 ES350 - could not locate the switch (it's referenced in my manual, but picture was not very helpful). Instruction to locate switch was perfect. Worked like a champ. Thanks! Victor
the picture shows hole's 3 and 5 not 3 and 4.
My ‘06 470 developed a TOTAL UP rear end with a very bumpy ride. I followed the advice from the Forum and YouTube. I replaced the TWO ride SENSORS, L and R. I purchased the parts on Amazon, $109. 1. Raised rear end onto jack stands. 2. Removed wheels L&R. 3. SLOWLY removed each SENSOR. (I soaked the mounting hex bolts with JB Blaster) 4. Replaced SENSORS in reverse order. 5. Once the wheels were back on the ground I disconnected the battery for 10mins. 6. Once electric power was restored the car VERY SLOWLY returned to NORMAL stance. 7. I spent 8hrs total. I’m NOT a highly skilled mechanic, with a very basic tool box.
In your pic you show in the OBD PORT the clip in the 3rd top hole and the clip in the 4th hole (is this correct)? It’s not worked for me? Please let me know as it’s annoying with the VSC light on all the time. thanks, ken
I have the opportunity to purchase an '06 Lexus LX470 (170k Miles) in Cypress Pearl - Ivory interior in great condition. All necessary repairs and maintenance were performed this month. I have listed the large maintenance items below. I am curious what a good market range is for this vehicle? Please advise. Timing Belt Water pump Valve Covers Heater tees Timing Cover Crank seal Cam Seal Radiator Rear main Sea
Topics
