Sreich123 Posted August 20, 2017 Share Posted August 20, 2017 I have a Lexus IS300 2001. Last night my windows were getting foggy with the cold air on (yes it was working fine) so my fiancé started playing around with the temperature for the windshield and put it up to about 75. Well when he went to put it back on cold air, it just kept blowing hot air. We tried restarting the car, letting it sit for a while. It was recharged last year. Everything is connected, no blown fuses. Like I said it was working fine 2 mins before the heat was put on. Please help! I'm in GA. This heat sucks! Quote Link to comment Share on other sites More sharing options...
Lexus_DK Posted August 20, 2017 Share Posted August 20, 2017 Which part of Georgia are you located Quote Link to comment Share on other sites More sharing options...
Sreich123 Posted August 20, 2017 Author Share Posted August 20, 2017 Douglasville Quote Link to comment Share on other sites More sharing options...
Lexus_DK Posted August 21, 2017 Share Posted August 21, 2017 Check to see for any signs of coolant leaks. Make sure the engine isn't overheating. Have engine running with ac on and inspect the coolant temp gauge. Also, Make sure the cooling fans are kicking on. If your stumped at this point, I'd have a good shop check out the ac system, make sure it wasn't overcharged with refrigerant. Maybe the ac compressor is failing or locking up. Quote Link to comment Share on other sites More sharing options...
