dblbassoon Posted August 17, 2017 Share Posted August 17, 2017 The passenger side door lock on my SC300 works manually on the inside of the car,....but does not respond from the outside,...even when I use my electronic key fob. Have checked the interior door lock switches (on both sides) which seem to work,...but even when 'unlocked' the passenger door handle on the outside of the car doesn't work. Anyone else have this problem? Thanks, Kevin 96 SC300 Quote Link to comment Share on other sites More sharing options...
JohnH Posted August 17, 2017 Share Posted August 17, 2017 The usual culprit is an inexpensive tiny plastic piece that clips onto the handle. I've changed both of mine. Here's the link on another forum. https://www.clublexus.com/forums/performance-and-maintenance/200819-so-your-door-handle-doesnt-work-diy-w-pics.html Quote Link to comment Share on other sites More sharing options...
dblbassoon Posted August 17, 2017 Author Share Posted August 17, 2017 Thank you!!! kevin Quote Link to comment Share on other sites More sharing options...
