AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
jbtvt
Does this drivetrain play look/sound normal?
1 post in this topic
Just bought a new '98 GS400, 111k miles, dealer maintained, no codes, runs and shifts strong. Body has some scratches and hail damage so I got what I hope turns out to be a good price. It has a pretty severe vibration at high speeds, get noticeable maybe around 50 and by 80 I'm shaking in my seat. It seems load dependent - stronger under accel and decel than cruising. Mounts and CVs seem OK, the vibration damper is a little cracked and I'll probably replace now but doesn't seem terrible
The center support bearing seems to allow quite a bit of play but the rubber is solid and shows no signs of cracking anywhere, so I assume its supposed to behave like this? When I wiggle the front shaft though I hear a noise which seems to be the splines moving around. It looks like a sort of compression fitting to me, anyone know if that's the case? If so, should I try to tighten it up a bit or better to leave it loose so it slides? Here's a video of what's going on there.
https://youtu.be/CVqdMOTHQww
Share this post
Link to post
