AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
sandiegomike
Burning rubber smell in RX330 engine compartment
An intermittent burning rubber smell occurs after medium amount of city driving in 70 degree and dry weather.  Emergency brake does not seem to be engaged.  Smell is limited to the engine compartment, no smell around wheels and no unusual smell from exhaust pipe.  Any thoughts or troubleshooting suggestions?  Thanks
Share this post
Link to post
Have you checked around the exhaust manifold in the engine bay? If anything like a rubber hose or plastic part makes contact with either manifold (left or right), a burning smell can enter the driver's area.
Share this post
Link to post
Check the air conditioning belt, Maybe the air conditioning pump is freezing up and causing the belt to stall.
Share this post
Link to post
I had a compressor clutch freeze up on another vehicle and it burned the belt so bad that the belt broke and wrapped around the crankshaft pulley.
Share this post
Link to post
Good to know. I'm going to do a search of the engine compartment for evidence of burning or chafing this weekend. I will keep the suggestions that you others have made in mind. Fingers crossed for something straightforward and relatively easy to repair. Thanks for the response.
Share this post
Link to post
By the way if the compressor clutch is bad, it can be replaced independently of the compressor.
Share this post
Link to post
