inreemote Posted February 8, 2017 Share Posted February 8, 2017 both widows do not work, how can I fix this problem. Quote Link to comment Share on other sites More sharing options...
TrevC Posted February 8, 2017 Share Posted February 8, 2017 Have you checked the fuses? Quote Link to comment Share on other sites More sharing options...
inreemote Posted February 8, 2017 Author Share Posted February 8, 2017 I Have found the fuse box I am unable to tell which fuse goes to what, can Help with that? I also have the dash lights stay on when the key is out of the car. So i have to disconnect the battery or it will drain it. Quote Link to comment Share on other sites More sharing options...
inreemote Posted February 8, 2017 Author Share Posted February 8, 2017 Any pictures you can send wound be helpful and most important THANK YOU for your time. Quote Link to comment Share on other sites More sharing options...
TrevC Posted February 9, 2017 Share Posted February 9, 2017 I would advise you take it to an auto electrician as if the vehicle is powered up with the ignition key out this could be quite a serious issue. Worth getting it checked before it leads to something more serious. Quote Link to comment Share on other sites More sharing options...
