ABS/VSC Lights
Hi...welcome to the Forum
I would be tempted to measure each individual wheel speed sensor for resistance or scope waveform to determine if they are all working okay.
Also, check tyre pressures...sounds daft but ABS measures wheel rotation and if the rolling diameter is altered by for example, one of the tyre treads being substantially lower than another or tyre pressures lower than another this can trigger a fault.
Let us know how you get on with this fault
Cheers  Trevor
