Truck keeps dying
I have an 06 RX 400H.  I bought the truck in 2011 and since then have purchased 2 batteries for it.  I do use the auto light feature and I have auto start could these two things be draining my battery while the car is off?  Or could it be the smaller battery that needs replacing?
Suzanne, I would hazard a guess that there is and has been a grounding problem w/ your vehicle. I think 2 batteries in 5 yrs. is one too many, so it is probably time to take it to a good mechanic to find the problem. Good luck!
The auto headlight feature should NOT drain the battery. If you are referring to "Remote start", then there is a chance that it was wired incorrectly. An auto electric shop should be able to isolate the problem, quickly.
