VigorousBrando Posted March 15, 2014 Share Posted March 15, 2014 Hello everyone, I'm looking for some input on how to best install an A/C compressor to my '94 SC400. I haven't done this before. The compressor I'm installing is OEM and was pulled out of a fully charged A/C system on a '97 SC400. I'm replacing my compressor after some research into my blinking A/C light (as seen here).I figured all I had to do was take out the junk compressor and put everything back together with new o-rings. But now I'm under the impression that the entire system needs to be pressurized with a vaccum and professional guages are needed to make sure everything is in order. It's also been suggested I get a $15 A/C Dryer from NAPA to replace the old one. Finally, I've been told that I can find potential leaks in other areas while I install the compressor using a blacklight. I think there's a big one somewhere since the junk compressor had refrigerant in it.In any case, I'm debating on how best to go about things before I start installing the compressor. I've attached the pages I'm following in the SM to this post.As always, thanks for your help in advance. AC Compressor SC400.pdf Quote Link to comment Share on other sites More sharing options...
