raregula Posted October 18, 2012 Share Posted October 18, 2012 An anti-theft method is a good decision that comes stock or typical on some newer models of automobiles. The technique prevents your car or truck from being stolen and can, in some cases, lock the engine when it senses a threat. That causes a really serious trouble at instances due to the fact it could possibly lock itself for no cause meaning that you just can??t get started your vehicle. If this occurs, you will have to turn off the anti-theft method by tricking the auto into thinking the threat has passed. Instructions 1 Appear in your dashboard to get a light that indicates an anti-theft process. On most cars it ought to say ?theft process? underneath a smaller light. This shows that you just do have an anti-theft system on your automobile and that it is currently working. 2 Check the wiring below the car to generate positive the wires are intact and that they aren??t missing or loose. You may uncover what wires go to your anti-theft method by seeking at the owner?s manual that came together with your car or truck, or by borrowing a manual from the library. 3 Examine your battery to make certain it really is working. If the battery is dead, your automobile will produce a soft whirling sound or the engine will only click whenever you try and turn it more than. Possess the car or truck jump started in the event the battery is dead. 4 Place your crucial within the ignition and twist your hand forward. You desire the interior lights and radio to come on, but not the engine itself. In some cases you may need to turn the important backwards to perform this, nevertheless it will depend on the make and model with the car. 5 Wait at the very least ten minutes just before you remove the important. This does place some pressure on the battery so you must make certain the battery is working before you do this. Immediately after 10 or 15 minutes, the anti-theft system on your car will shut itself off and also you will see the light on your dashboard turn off. As soon as this occurs, you may very easily start out your vehicle. Suggestions & Warnings Obd2 tool technique support Quote Link to comment Share on other sites More sharing options...
raregula Posted November 15, 2012 Author Share Posted November 15, 2012 what do you think about it? Quote Link to comment Share on other sites More sharing options...
raregula Posted November 20, 2012 Author Share Posted November 20, 2012 what do you think about it? Quote Link to comment Share on other sites More sharing options...
raregula Posted December 12, 2012 Author Share Posted December 12, 2012 any ideas? Quote Link to comment Share on other sites More sharing options...
