AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
Sign in to follow this
lrufo
Window Controls
lrufo    0
Hello- I am unable to control the passenger windows and locks anymore.
Can someone assist me with this issue?
Regards,
L
Share this post
Link to post
maseace    12
The windows have to be initialized if the battery is disconnected or if the window controls are disconnected. Go to each window control at each door and run it all the way down then up. The driver door controls should then work normally.
Share this post
Link to post
LEXIRX330    11
Based on his post about the locks also not working I am not sure that this will work. It's been a long time since I have had to do it but if I remember correctly the locks ail continue to work. But this was the first thing I thought as well.
Get this I know someone who has a rx330 and they had the battery changed and all of the windows stopped working so they took the car back to jiffy lube where the battery was changed. Jiffy Lube sent the car to the Gemini Service center who diagnosed all the window modulators bad. They said they were going to charge like $1400. Anyway I knew this person and when they told me about it I told them the little trick above and they all worked fine. Give it a shot but like I said to my knowledge your locks should still work but I may be wrong. :cheers::cheers:
Share this post
Link to post
lrufo    0
No joy with the listed suggestion. Any other options?
Thanks for replying
L
Share this post
Link to post
cduluk    17
Can these functions be controlled if you use the switches on each door's own panel? Can the drivers window and lock be controlled via the panel on the drivers door?
What about the lock switch on the front passenger door, does that work?
Share this post
Link to post
lrufo    0
Yes, the switches function on each door's panel. And, the front passenger door lock switch also functions.
But, no, the drivers lock switch does not function -cannot lock any doors.
L
Share this post
Link to post
cduluk    17
Probably a loose connection within the drivers control panel. Any chance your RX is still under warranty?
Share this post
Link to post
lrufo    0
Actually, yes. I purchased it used with a warranty.
I am assuming it needs to be taken in based on your response.
L
Share this post
Link to post
cduluk    17
Yeah, i would definitely have Lexus take a look... If it's something simple they probably won't charge you, and if it's something more complicated they'll replace the broken part free of charge. <_<
Share this post
Link to post
