DR LS 460L AWD Posted February 21, 2011 Share Posted February 21, 2011 Please let me know if anyone has experience front end rattle under the hood at low speeds up to 25 MPH. I have a 09' LS460L AWD. It feels as though the front end is going to fall off. I have notified the dealership numerous times while being serviced and they claim there is no rattle or that they have tighten something under the hood that should help. After my 25K service the noise is now worse and easily detected by others. Is this something others have experienced? Quote Link to comment Share on other sites More sharing options...
Ed Darte Posted February 22, 2011 Share Posted February 22, 2011 Please let me know if anyone has experience front end rattle under the hood at low speeds up to 25 MPH. I have a 09' LS460L AWD. It feels as though the front end is going to fall off. I have notified the dealership numerous times while being serviced and they claim there is no rattle or that they have tighten something under the hood that should help. After my 25K service the noise is now worse and easily detected by others. Is this something others have experienced? I have a 2009 SWB AWD with approx 17K and have not heard any such rattle. Quote Link to comment Share on other sites More sharing options...
gs3sttico Posted March 13, 2011 Share Posted March 13, 2011 Hi. Could the rattle be from a known Lexus LS460/460L problem, a faulty brake actuator? There's a service bulletin out on this and it is noticeable at low speeds -- actually, any time you brake it sounds like low-grade barking or popping -- that's air leaking from the brake actuator. But you seemed to say you get the rattle even when not braking. Quote Link to comment Share on other sites More sharing options...
MikeE123456 Posted April 13, 2011 Share Posted April 13, 2011 Please let me know if anyone has experience front end rattle under the hood at low speeds up to 25 MPH. I have a 09' LS460L AWD. It feels as though the front end is going to fall off. I have notified the dealership numerous times while being serviced and they claim there is no rattle or that they have tighten something under the hood that should help. After my 25K service the noise is now worse and easily detected by others. Is this something others have experienced? I have a 2011 LS460 SWB AWD and haven't experienced any rattles. It is the quietest car I have ever driven – so far at least. Mike Quote Link to comment Share on other sites More sharing options...
forthlexus Posted April 17, 2011 Share Posted April 17, 2011 Hello, just came across your post regarding the front end noise. I have a 2010 ls460 with just about 10,000 miles. While on a recent trip to Arizona I was going about 20 to 25 mph slowing in traffic for a stop light. It was actually just slow moving rush hour traffic with a slow moving pace of tops maybe 40 mph. Anyway, all of a sudden I had a really loud reverberation from under the hood that sounded as if something was beating the side of the car with a hard rubber hammer. It was very rapid in sequence and really seemed as if it was not far from my feet. There were no warning lights or fault indicators on the instrument panel. I am sure that I did not hit anything in the road so I was very concerned. I took the car to 2 different Lexus dealers and they looked it over and said that they were concerned that it sounded like a brake actuator issue that had occurred on one of the other Lexus models--but they had not heard of any issues with the ls460. The problem has only occurred once and I have been driving the car about 6 weeks since then with no other problems. Regardless, it sounds like the same thing that may have happened to you. I hope this might support any other issues that you might have. If you have found out your problem I would appreciate you posting the fix. Best regards forthlexus Quote Link to comment Share on other sites More sharing options...
MikeE123456 Posted April 18, 2011 Share Posted April 18, 2011 s Quote Link to comment Share on other sites More sharing options...
benw Posted June 30, 2015 Share Posted June 30, 2015 I just bought a Certified 2012 Rx350. After about 30 minutes of highway driving I get a sound like corn popping from engine compartment. It will stop for a while and then start again. Not a rattle, not a ticking. Not a slow speeds, not until well into the trip. Quote Link to comment Share on other sites More sharing options...
sadclown Posted August 14, 2015 Share Posted August 14, 2015 It is definitely a suspension problem. Have it checked by a mechanic. Quote Link to comment Share on other sites More sharing options...
Don Draper Posted October 7, 2019 Share Posted October 7, 2019 I have a 2008 RWD LS 460 that has front end rattle going over bumps.replaced control arms and still have rattle. Mechanic says suspension is solid. Any recommendations? Quote Link to comment Share on other sites More sharing options...
JM111085 Posted January 11, 2021 Share Posted January 11, 2021 On 10/7/2019 at 1:30 PM, Don Draper said: I have a 2008 RWD LS 460 that has front end rattle going over bumps.replaced control arms and still have rattle. Mechanic says suspension is solid. Any recommendations? Hi Don, I’m experiencing the same issue on my 2008 LS460. I too replaced control arms, twice. Once aftermarket parts and recently at the dealership. I was taken to the cleaners and told more parts need to be replaced, all with no guarantees that the issue would be fixed. Any luck on your end? Quote Link to comment Share on other sites More sharing options...
