AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
Sign in to follow this
jwis250
Is250 Motor Oil Capacity
jwis250    0
The IS250 has a motor oil capacity of 6.7 quarts, would it be okay to just use 7 quarts? My problem is measuring of the 0.7 quarts and saving the remaining 0.3 quarts every time I changed the oil. Will it harm the engine if I use 7 quarts?
Thanks
Share this post
Link to post
F14Scott    0
The likelihood of 0.3 extra quarts of oil in the crankcase and sump doing any damage to your car is extremely low. In 25 years and a couple dozen cars and motorcycles, I've rounded up to the nearest quart and never had a problem. Large quantities of extra oil (like two or more extra quarts) can push past the rings and/or froth, but a few extra ounces won't hurt you.
Share this post
Link to post
jwis250    0
Thank you! Next time I'll just pour in 7 quarts.
Share this post
Link to post
Old school    0
Thanks
Share this post
Link to post
Old school    0
I've been putting 6.5 quarts at each change. This will bring it to the full mark exactly. Don't over fill. If you are using quart bottles they should be marked. If you are using bulk, go to Walmart and get a cheap glass measuring cup.
Share this post
Link to post
jwis250    0
Thanks for the suggestion, 6.5 quarts is a good round number. I can save the half quart for the next oil change.
Share this post
Link to post
