bigjun18 Posted June 7, 2010 Share Posted June 7, 2010 WHAT UP HAPPY TO BE A MEMBER BUT NOT HAPPY WITH THE CONDITION OF MY 99 GS300, HERE'S MY STORY CHECK ENGINE LIGHT STOP COMING ON WHEN I TURN ON THE IGNITION THE CAR JUST KEEPS TURNING OVER BUT NO START AND STILL NO ENGINE LIGHT AT ALL I THINK THE ECU LOCATED UNDER THE HOOD MAY BE BURNT OUT I DON'T KNOW WHAT TO DO. PLEASE ANYONE HAVE ANY IDEAS ON WHAT TO DO BECAUSE (JR.) IS LOST HELP PLEASE! Quote Link to comment Share on other sites More sharing options...
FrankT Posted June 11, 2010 Share Posted June 11, 2010 You are on the right track, no power to the ECU. FIRST the EFI fuses need to be checked. Under the hood and in the kick panel. Then verify the EFI relay is working. Hope this helps... Quote Link to comment Share on other sites More sharing options...
Infamous 1 Posted July 7, 2010 Share Posted July 7, 2010 GO to an auto parts store and rent a code scanner. After you pull the code. GOOGLE is your friend to help you diagnose your problem. GL Quote Link to comment Share on other sites More sharing options...
