2007 Rx 350 Check Engine And Vsc Light On
I swear the car was making strange vibration noises in the garage last night, It sounded like an air pump. The car was off Today started it and the light s are on ,no noise now- any ideas
I checked for loose lines, gas cap tight, have not even fueled it a week or so- suggestions
Thats two different problem you are dealing with, the air pump noise is just the gas vapor system purging itself. The check engine and VSC light can mean a number of things. Have your dealer pull the error code and determine what it is.
thanks , did that today, very prompt service, treated me well, error code was vent system off of tank , they have ordered the parts, all under warranty, all is good, thanks
