Trunk Won't Close
The latch will be "open" when you look at it. It closes when the striker engages the round bar at the bottom of the trunk.
Open the trunk all the way and take a small screw driver and push up on the flat part of the moving latch. The latch should pop closed. If it does, cycle a few times, by releasing with the button above the license plate, closing and then releasing. It that's working it should latch and close. If it doesn't cycle, then there is soemthing wrong with the mechanism and it needs replaced.
Also make sure the part the latch hooks into at the bottom of trunk is in position and hasn't come loose and got pushed down so the latch can't engage.
