Tells Us About Your Car And Its Mods Or Problems
SKperformance
List your model, year ,
# of owners ,
price when bought and from where
lenght of ownership and attributed problems and repair costs.
Also mention where you had it fixed ( lexus, independent, midas or diy).
When it was done.
Any mods done to the car and its costs.
If desired your age and insurance you pay.
If you have any picutes in the gallery put links in the post so we can have an idea about the car.
Please only post once and if you have a question either pm the member or make a new thread .
This will keep the page from being filled with excess.
  • 3 months later...
  • Replies 67
  • Created
  • Last Reply
Top Posters In This Topic
1996 LX-450
Purchased 3/22/02 from a used car lot in Virginia Beach with 81,538 miles on it
Now has 118,000 miles
No repairs yet, just routine maintenance when I remember it
Driven hard
Stuff
Some cool tail light guards I ordered from somewhere
Parrot CK3000 Bluetooth handsfree kit, an absolute must
Alpine amp and 12" sub added to factory system
SleeOffRoad replacement front bumper "in the mail" as I type
Most importantly: actual flip-out cupholder from SleeOffRoad
Maybe a suspension lift next...
Comments
Since I bought my LX-450 it has been driven from east coast to west coast and back again, survived a monster Dallas hail storm with not one ding (see my thread on this incredible story), dusted through Nevada desert heat with low coolant, and sat overnight in a frozen rest stop ditch in the Colorado mountains... and all the while it has never even flinched!
Some photos of my baby
:cheers: to the best vehicle I've ever owned
ALSO HAVE 2000 LX470. 76,000 MILES. OWNED SINCE NEW. TRANSMISSION TOTALLY SELF DESTRUCTED AT 71,500 MILES. LEXUS BOUGHT THE REPLACEMENT TRANSMISSION ($2,800+), I PAID THE LABOR ($800).
74,250 MILES THE "VSC" LIGHTS CAME ON. LEXUS RESET THE CODE AND TELL ME I NEED A NEW THROTTLE BODY. SOUND FAMILIAR?
76,000 MILES THE STARTER/SOLENOID RETURNS GET JUST ONE "CLICK" WHEN I TRY TO START. CAR WILL ACTUALLY CRANK AND START MAYBE 1 IN 20 ATTEMPTS.
BEAUTIFUL CAR BUT LONTERM QUALITY VERY DOUBTFULL.
  • 3 months later...
97 LX450 with 77k
Bought it 10/04 with 67k, 2cd owner.
34 and pay $900/year in insurance
DIY maintenance to date (mostly PM):
Repaired leak at rear main upper pan arch, front axle service (new seals, trunion bearings, wheel bearings, birf repack), new plugs, new fluids: diffs, tranny, t-case, PS, brake, coolant flush, new EGR modulator, VSV for EGR, OEM belts, extended breathers into engine bay, front brakes, new starter contacts and plunger, new shocks, installed CDL switch w/ pin 7 mod., amp. and speaker box, upgrade lighting harness for front lights, removed and painted roof rib rails, stripped and painted center caps.
To do list:
Remove and grease driveshafts. (done)
Replace PHH (done)
Wish list:
Upgrade suspension with 2" lift, new meats and slee sliders.
BTW, before buying this rig, I had never done more to a vehicle than change the engine oil and battery and the beast is running good! They are easy rigs to work on, especially stuff like fluid changes and brakes. Don't get hosed by the stealer (not to step on any toes).
:cheers:
Rookie
  • 2 months later...
Hey everyone,
I seem to be having a problem with Lexus and the tech assist department. Can any owners post some documentation please.
99 LX470 with 75,000 miles.
Started last winter in Colorado. Engine knock when started in cold temps. Sounds like a diesel truck....ie knock, knock, knock....lasted for 30 seconds or so. We didnt leave the truck outside that often...but the noise was worse the colder the temps. I really noticed it when I had to move the truck in the driveway after a cold start....it sounded like a diesel. on accel....knock, knock, knock.
Ok, winter 2002 there were no abnormal noises heard...45k on the odometer.
Ok, winter 2003 it sounded like this with around 60k on the odometer.
10 degrees....it would make noise even at idle on start up.
20 degrees....less noise but could still hear it.
30 degrees....hard to tell, but if you put it in gear and loaded the engine it would knock.
Ok, fast forward to this year winter 2005 in Oregon with 75k on the odometer.
30 degrees...much, much louder knock....same knock as last year just louder at a warmer temp. Also, the knock will last for 2-3 minutes...or if you drive the truck it sounds like a constant knock, knock with engine speed. You can hear it outside, inside and all around the truck. Stand fifty feet away and listen as the truck takes off. Yes, you hear it just like a diesel truck taking off.
40 degrees....less knock noise that 30 but its very clear and lasts for the same 2-3 minutes.
50 degrees....I heard it this week on a cold start. Put the truck in gear and moved it in the driveway....there it was the diesel knock noise.
So, the trend is getting worse and I made the appt to have it looked/listened to. I had to leave the truck overnight. Got the call...and Lexus techs said could not duplicate. Ok, leave it again....same response. 3rd day I come to pick it up and take the techs out on a 49 degree morning. I start it, put it in gear and there is the knock. Two techs heard it....jumped out and listened. It lasted for about 2 minutes and the techs said they would have to call tech assistance. I told them that the noise was about a 3 on a scale of 1- 10 because it was farily warm that morning. Ok, now the round and around with Lexus customer service. Tech assist says its piston noise and normal. Lexus customer service says that the dealer is saying its normal piston noise. .....round and around general passing the buck.
So, I come to find out that the Tundra/ Sequoia group have been having this problem for a couple of years but on a much higher/ louder scale. Nothing is mentioned in the Landcruiser circles....nor here in the LX40s circles. These are different engines than the Tundra and should not have this clearance issue with the pistons.
Bottom line, noise is wear...and its getting worse. And, its not several pistons...it is just one piston. The knock is one piston, period.
Are these things Chevys that destruct at 100k? I am begining to wonder if all the hype is just that.
__________________
Cheers,
Dave Hall
99 LX470....special knocking diesel model. We were thinking about a new GX470 but forget it now.
92 SC400
00 LS400
SKperformance,
Would you please assist me with my PM or email request to gglx470:
I ask that someone with the ability to email follow members (I am not yet a Gold Member) please send an email or PM to member gglx470 asking this individual to contact me at fzkzrz@aol.com. I need some information from one of his postings back from Aug of last year dealing w/ navigation system demons. I ask that maybe someone take a minute or two, look up his information unders the "MEMBERS" link at the top of the page and foward this message. It is frustrating, I have no way of contacting this individual. I am a registered member of this forum...:cries:
PLEASE SOMEONE HELP ME. I am a fellow Lexus owner after all... :)
Thank you.
Lexi98.....
One word: shocks. When I bought my 96 LX450 it did the same thing. Bounced all over the freakin place. Flying through the interstate in New Orleans, all I could do was just hang on. Got new shocks, and all is right with the world. Fixed every bit of it.
I have a 97 LX 450. 2nd owner, maybe 3rd. Has roughly 118k miles on it. Living in Michigan right now, and during the biting cold winter months, and at the first start of the day, when I turn the steering wheel, I hear some obnoxious loud sound, almost like the lubricant is NOT warmed-up yet in the steering column. But after driving throughout the day, the squeek is less and less. Thoughts?
For now, I'm just dealing with the problem and am soon moving to a warmer climate.
  • 4 months later...
I have 2002 LEXUS LX470 that I bought from an auction last month.
The navigation was working fine until a few days ago, it says NO DISK DETECTED. There is a blue disk in the navigation box under the passenger seat. I even bought a different black colored disk from ebay which is a later version, but still giving me the same message.
Did anyone else run across anything similar? The dealership wants to charge me a $$$DIAGNOSIS FEE$$$ and then may be they'll ask $$$BIG MONEY$$$ to fix it too.
:cries: PLEASE HELPPPP !!!!!
Lx 470/2000 $1500.00 repair bill at 60,000. Needs needs new throttle Body. I am so  P.. O.. right now can't tell Ya. Any one else with the problem.
Have 98 LX 470 with 58,000. Have experienced sudden loss of power when turning from a stop, engine hesitates, no acceleration...been going on for a year. Lexus dealer replaced catalytic converter but still have problem. They now suspect it is the throttle body or the sensors in the electronic throttle system. lexus Dealer and Lexus HQ argouing about what is covered under extended warranty.
Have seen sever al postings of loss of power with the 2004 and 2005 sedans but not a lot on the 470. Anyone else having a problem.
I am the second owner of a 1999 LX470 and it has 80K miles.
When I turn the ignition key the engine starts on the first twist,
without me even touching the gas pedal.
Suddenly this morning when I turned the key I can hear the
starter turning but the engine would not ignite.
After a few failures, I tried to depress the gas pedal(old fashioned way)
as I turned the key and it finally started. Once it started
everything was fine and I was able to drive normally.
Any idea what the problem may be?
I have a ''99 LX 470
Bought new in Oct of '98 for $61,000
Dealer maintained for all services up to the end of the 60K Warranty. Nothing but routine service.
Replaced the Michelins and the front brake pads at 70K
Major Service at 98K, engine missing. Diagnosis - Bad Fuel Injector
Driver's window fell down at about 105K. Broken plastice window support. Fixed it myself with a free part from the local SafeLite Auto Glass shop (glass shops wanted to sell a whole new window)
Replaced the brake pads again yesterday at 118K. Still had 50% but I have a shimmy. Looks like it will need the front rotors turned or replaced.
Looks like the Michelins will be good for at least another 10K.
Replaced one headlamp bulb and a couple taillight bulbs somewhere in the 90-100K mile range.
Thats it! This has been and continues to be an exceptional truck.
There is an odd "shudder" when starting from a dead stop with the front wheels turned. I think it's in the AWD transfer case. It's been getting more prevalent since it was in at around 98K for the engine miss and major fluid service. Thinking about trying a different diff fluid type.
  • 2 months later...
I'm having a new issue and I'd like some advice.
The car is a 2002 LX470 with 50K miles.
When the car is in D and at a complete stop, there is a groaning noise coming from (what sounds like) the steering column. Move the steering wheel does not make the sound louder or softer, it is constant.
When at the stop, if If I put the car in N the noise goes away.
Any ideas what could be making this noise?
  • 6 months later...
I have a 2002 RX300 that started with the same problem last week. Did yours get fixed? If so, what did it?
Thanks,
# of owners ,
When it was done.
LX 450
1997
2nd owner
Purchase price ~ $30k USD, Lexus of Sacramento.
Purchased mid-2002
Repairs:
radiator replaced with brass-core radiator for 93/94 Toyota Land Cruiser
all cooling system hoses replaced (except for PHH)
fan clutch replaced
front and rear rotors replaced
various brake pads replaced
various drive belts replaced
window washer diverter valve (x2) replaced
speedometer speed sensor replaced
radio antenna replaced
starter replaced
power steering pump replaced
fuel pump braket wire repaired
exhaust (including muffler and resonator) replaced (cat-back)
tail light bulbs replaced
Mods:
ARB front bumper
Slee Offroad rear bumper w/tire carrier
Slee Offroad sliders (replacing the running boards)
Slee Offroad transfer case skid plate
Removed plastic body cladding and flares with truck bed liner
Safari Snorkel
Scolaro LED lights overhead and in doors
Washer bottle relocated
Custom Rear Cargo drawers
12V power to cargo area
Old Man Emu 2.5 inch suspension lift
Cobra CB
Black Rock Crawler wheels
315/75 R16 Goodyear MT/R
John Deere HIR light bulbs
Lightforce 240 Blitz offroad lights
Pending Mods:
2nd Battery
Isolator/Combiner for 2nd Battery
Winch
Expedition roof rack
Rooftop tent
1.25" wheel spacers
Other tidbits currently in the LX 450:
ARB Freezer/Fridge
XM Radio
Garmin 2620 GPS
  • 2 months later...
I am having the exact same problem. Today Lexus dealership told me $1600.00 for a new player because the optical reader went out in the nav syste,. The nav is made by Fujitsu ten. Let me know if you find out anything else
Tom
I have the same problem "no disk detected" on my navigation system. I got a $2050 quote. It seems absurd to me to have to pay $3000 for a machine that breaks down 3.5 years later and then have to pay another $2K to get it fixed.
97 lexus Writes:
"I HAVE A 97 LX450 AND MY DISC CHANGER KEEPS GIVING ME AN ERROR CODE 23 DOES THE CHANGER NEEED TO BE REPLACED OR CAN IT BE FIXED?"
I believe all electronic devices can be repaired by a qualified electronics store. There should be one in your home town that you can take the reader to and have them repair it.
When I lived in Syracuse, NY I went to a place called United Radio and they could rebuild anything.
http://www.unitedradio.com/auto_dealers.shtml
You should be able to find out if they can work on it.
  • 9 months later...
