Vsc Indicator Light On 06 Gs 300
  • Please log in to reply
20 replies to this topic
#16 Lexus GS430 Guzzler
Lexus GS430 Guzzler
    Advanced Club Member
  • Regular Member
  • PipPipPip
  • 111 posts
  • Model: Lexus GS430
Posted 26 December 2009 - 10:39 PM
I just got this. I went to Autozone and got a OBD2 scanner and saw that P0441 and P0455 came up.
My personal friend/mechanic says that there's 3 possible issues: the vacuum seal valve, charcoal canister, or gap cap's rubber gasket. Says it's probably the gasket, and I think so too - when I undo the gas cap, it does not hiss - meaning that it's not retaining pressure. I'll see if Lexus can figure it out.
Have something to contribute?
Sign in or register to start a topic...
#17 Austin GS
Austin GS
    New Club Member
  • Regular Member
  • Pip
  • 4 posts
  • Model: 06 Lexus GS
Posted 10 January 2010 - 11:36 AM
Any other updates? I started another post here about a similar issue with check engine/VSC lights coming on. I have had the gas cap replaced by the dealer, but it did not fix the problem.
#18 RonnyB
RonnyB
    New Club Member
  • Regular Member
  • Pip
  • 8 posts
  • Model: GS 300 AWD
Posted 10 January 2010 - 02:16 PM
i SPOKE WITH THEM YESTERDAY AT THE DEALERSHIP AND THEY SAID TO UNSCREW THE GAS CAP AND DRIVE AROUND FOR ABOUT 3 MILES AND IT SHOULD TURN ITSELF OFF....NO LUCK...I'M TAKING IT IN fRIDAY TO FIND OUT WHAT'S UP WITH IT....ANY ONE ELSE HAD THIS PROBLEM????
Exact same thing happen to my 06GS300.. Dealer replaced gas cap under warranty and problem went away. According to the dealer, this is very common.
#19 nickjhowe
nickjhowe
    New Club Member
  • Regular Member
  • Pip
  • 4 posts
  • Model: 06' GS300
Posted 18 January 2010 - 05:47 PM
VSC lights just came on mine. Let's see what the dealer says tomorrow...
#20 HomieG
HomieG
    Club Member
  • Regular Member
  • PipPip
  • 39 posts
  • Model: '06 GS300 RWD
Posted 11 February 2010 - 05:47 PM
You can add my '06 GS300 to the "replace fuel cap" for the P0456 code, with VSC, TRAC and Check Engine lights/warnings on. Cleared it myself a couple of weeks ago after re-seating the fuel cap gasket. But the code got triggered again yesterday. Brought it to the dealer today and they replaced the fuel cap. Interestingly, the service order says "replaced fuel cap, cleared code as per TSIB L-SB-0168-09". I hadn't seen, or missed, any postings of this issue related to a TSIB.
Part number on the new cap is 77300-47010 per the service order.
Presumably the -09 suffix means it's a 2009 TSIB, but can't seem to find it via search here or google.
I'm curious to read that TSIB (L-SB-0168-09). It's my nature to be curious! Anyone have this TSIB and could post it, or a link here?
#21 nickjhowe
nickjhowe
    New Club Member
  • Regular Member
  • Pip
  • 4 posts
  • Model: 06' GS300
Posted 19 February 2010 - 08:27 PM
Yup, same as everyone else they replaced the fuel filler cap...
Not what you're looking for?
Register now, we have a huge community of enthusiasts to answer any questions you might have
