A/c Issue / Diagnosis Help
tjmc11
Today my a/c light began to blink (did not run through water which is a common cause). The A/C then suddenly quit cooling. This happened suddenly. I hooked it up to my A/C machine and tested the vaccuum which held fine. It had 1.50 lbs of freon in it. Which to my knowledge is close to the correct amount (1.54 I think is reccomended).
Other info: The Clutch engages for about 2 - 3 seconds and then kicks out / off.
Does anyone have any ideas of what this could be. Is my compressor going out or is this a possible over-heating clutch relay going bad? Or possibly a switch/control issue? Please advise.....any help is graetly appreciated.
Your "A/C machine"?? What's that? Is that like a professional A/C machine where you can check pressures on the high and low side of the system? If you can, then you can check to see if you might have a blockage. We had a blockage and our A/C just stopped working. That meant a replacement of the compressor, drier, condensor, and expansion valve.
It could also be that your cabin filter is clogged. If you don't get enough airflow through the ventalation system, it will shut itself off (or so I've read).
There is also a discussion of a bad A/C relay on the ES models. Since the RX shares so much with the ES, it might be the problem. They have an upgrade A/C relay that is the replacement.
It could also just be a stuck expansion valve, which always seem to go out at some point.
Push and hold the AUTO button and the Recirculation button at the same time for 5 seconds. Place the key in the ignition while holding the buttons down. Turn ignition so ON and release the buttons. On your display screen you will see numbers flashing, they will cycle through and repeat. Post those numbers you see, hit the Recirculation button again and the AC system will run through a diagnostic test. Hit the OFF button to cancel everything out.
More info on the test:
SELF-DIAGNOSTICS
An Electronic Control Unit (ECU) within A/C-heater control
panel monitors system circuits and stores trouble codes in memory if
problems are detected. All codes, except Codes 22 and 23, are stored
in memory. Malfunction is current if Code 22 or 23 is displayed. To
retrieve stored codes, see RETRIEVING CODES. Codes are displayed at
temperature display. See Fig. 2.
RETRIEVING CODES
1) Simultaneously press and hold AUTO and recirculated air
switches. See Fig. 2. Turn ignition on. All indicators will flash 4
times, at one-second intervals. Tone will sound when indicators flash.
2) A/C system will enter self-diagnostic mode. To end
indicator check, press and release OFF switch. Read codes at
3) If trouble code is displayed, proceed to appropriate
trouble shooting procedure. See DIAGNOSTIC CODE IDENTIFICATION table.
Codes are displayed in ascending order. To slow rate at which codes
are displayed, press fresh air button to change display to step
operation. Each time fresh air button is pressed, display changes by
one step.
4) If tone sounds as code is displayed, problem currently
exists. If tone does not sound as code is displayed, problem occurred
in past and does not presently exist.
Code Diagnosis
00 ...............Normal
11 (1) ..........In-Vehicle Temperature Sensor Circuit
12 (2) ..........Ambient Temperature Sensor Circuit
13 ...............Evaporator Temperature Sensor Circuit
14 ...............Coolant Temperature Sensor Circuit
21 (3) ..........Solar Sensor Circuit
22 (4) ..........Compressor Lock Sensor Circuit
23 (4) ..........Pressure Switch Circuit
31 ...............Air Mix Door Position Sensor Circuit
32 ...............Air Inlet Door Position Sensor Circuit
33 ...............Air Outlet Door Position Sensor Circuit
41 ...............Air Mix Door Servomotor Circuit
42 ...............Air Inlet Door Servomotor Circuit
43 ...............Air Outlet Door Servomotor Circuit
(1) - If in-vehicle temperature is -4 F (-20 C) or less,
Code 11 may set even though system is normal.
(2) - If outside air temperature is -58 F (-50 C) or less,
Code 12 may occur set though system is normal.
(3) - If testing is done in a dark area, Code 21 may set
even though system is normal. Shine a light at solar
sensor and recheck codes.
(4) - Malfunction is current. Code is not stored in memory.
ACTUATOR CHECK
1) Perform step 1) of RETRIEVING CODES. When system enters
self-diagnostic mode, press recirculated air button. Each mode door,
motor, and relay will operate at one-second intervals. Press fresh air
button to display codes one at a time, and perform step-by-step
actuator check.
2) Check airflow and temperature by hand. Tone will sound
each time display code changes. Each display code is associated with a
system operating condition. Press OFF button to
cancel actuator check mode.
The code I received was 00. This tells me that there was no issue with the pressure/temp/ vent position/ cabin temp sensors. I am afraid I have a compressor issue. Purchased a compressor and will be installing it today.
I've encountered the same problem (flashing AC indicator on climate screen) a couple times. Turning off the AC and then back on has resolved the problem in both cases. I had Lexus service check but they couldn't find any problems. I'll check the codes next time it occurs. This is on a 2005 RX.
Both times were at initial startup in the morning. Ambient temperature was in the upper 70's F.
Update: Tested all sensors and they were fine. Clutch relay was fine as well. Replaced compressor and got cold air blowing again.
You may have an expansion valve issue OR your belts could be slipping due to water or looseness of the belt. IF your a/c works and then begins to blow warmer air, BUT AFTER you turn the a/c off for a while it begins to work again, it is more likely the expansion valve.
If it suddenly blinks and you turn it off and on again and it works, I would bet it is an issue with belt slippage or looseness OR a clutch relay issue.
[/quote/]
You may have a compressor issue. Have someone start the engine with the A/C off. Look at the a/c compressor and clutch assembly. Havesomeone turnt he a/c on and see if the clutch engages. IF the clutch does not engage, I would first guess yoru compressor is locked up.
Please post your results once you do this.
I'm having similar issues with my 03 ES. I ran this diagnostic and it is alternating "21" "24". I don't see a 24 listed?
OK. SORRY FOR THE BAD ENGLISH. THE SAME HAPPENS TO ME. I NOTICED THAT THE AC CONTROL BLINKS WHEN THE COOLING TEMP SELECTED BY USER IS HIGHER THAN THE EXTERIOR TEMP. JUST SELECT A LOWER COOLING TEMP AND PUSH THE BLINKING AC BUTTON AGAIN.O OFF AND ON AGAIN. IT WILL STOP TO BLINK AND COOL AGAIN.
IF IT DOES NOT FUNCTION, YOUR COOLING SISTEM MIGHT BE FROZEN. WAIT A WHILE UNTIL THE TUBES DEFROZE.
  • 3 years later...
  • 8 years later...
