92 Sc400 Ecu Cumputer Location?
305pimpc
IM HAVIN TROUBLE WITH THE CAR RUNNING BETTER I CHANGED CAP,ROTOR,,WIRES,PLUGS, RAN FINE FOR ABOUT 30 MINS THEN IT WENT INTO LIMP MODE NO POWER IT WILL NOT REV UP CLEAN OR STAY ON ! ANY IN FO I THINK IT MIGHT BE THE CUMPUTER THAT BURNED OUT BUT I CANT FINT IT SO I CAN OPEN IT UP! CAN ANYONE HELP?????
Computer is located under the passenger side kick panel, you have to pull back the carpet and remove the cover plate. I removed the glove box as well just to have alot more room to work.
Sounds like a fuel issue, or even ignition coil. (both much cheaper to diagnose first.) Search the forum for, Fuel pump bypass, so you can rule that out first.
THANKS i found it last night i opened it up and found some burned spots so i take it fried! it really sucks man i keep dumpin money into it and it wants to act stupid!!! ill post some pics later today of what i think is a burned ecu see what everyone thinks!!! but thanks alot for w/b with your info man its good to know people arent just reading it and going on! ill post updates for everyone a.s.a.p
how interchangabe are they like what years ecus can i play with my cars a 1992 sc400???
